It is currently Sat Jul 19, 2025 4:03 am
PostPosted: Thu Nov 23, 2006 3:24 am
Last Name: Johnson
State: CO.
Zip/Postal Code: 80224
Gobble, Gobb..AHHHHHHHHHHH
Purchased som 5x5x2-3" bowl blocks from Rockler-look great for rosettes, but whole block coated with wax. Wood is wet. What is best way to remove wax-seems sandpaper would clog like crazy.
PostPosted: Thu Nov 23, 2006 3:27 am
I use a scraper, Bob, then you could probably wipe it with naptha to remove any residual wax.
PostPosted: Thu Nov 23, 2006 3:29 am
Last Name: Johnson
State: CO.
PostPosted: Thu Nov 23, 2006 3:48 am
Yep, scraper...
My Grizzly oscillating sander deck had 1/8" of oily wax on it, YUCK! A dull scraper and a rag with some paint thinner made it shine.
PostPosted: Thu Nov 23, 2006 11:55 am
Never use solvents atempting to remove wax from wood because if it dissolves the wax it will soak it deeper into the wood. Use hot water and soap.
PostPosted: Thu Nov 23, 2006 10:09 pm
Last Name: Johnson
State: CO.
Thanks for the great heads-up Larry
PostPosted: Thu Nov 23, 2006 11:48 pm
Bob I a thin slice off on my band saw.
PostPosted: Fri Nov 24, 2006 3:41 am
Last Name: Johnson
State: CO.
thanks Bob
